Old 11-01-2010, 11:13 AM   #15 (permalink)
d0sitmatr
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
here I did some photoshop on the front clip to show the first stage of my plans for it.
stock front clip:
stage 1 aero front clip:
the bumper fill will be done by using expanding insulation foam to create the base for a mold, then using fiberglass for durability. this will basically be a fiberglass cover that will attach to the bumper.
Im also planning on closing/covering that gap between the hood and the lights/grill.
I already have GTS headlight covers that eliminate the crevices of the headlight assembly that I will be putting back on. and then I plan on filling any gaps in that area with the same method of insulation foam for a mold, then making fiberglass pieces.
and the final part of stage 1, Im in the process of picking up a set of projectors to run HIDs (the GTS covers dont allow much light through them as they block some of the beam without projectors)
~Mike
