OK, I was incorrect,
I believed you had the old style S10 T/S set up
You have the new style,
very easy to fix
those covers come off from the steering column
no need to pull the wheel
there are small holes in the bottom
look inside and see the screws that hold it all together
you may have regular #2 Phillips or they might be Torx heads
take out all the screws, remember where they went, some are for the cover halves and some are for retention to the column
one half will fall away easily
the other half will hang on the Ignition switch
just push that half over to that side
then you need to have a set of "Secure Torx"
the turn signal switch is held on with those.
get another switch either used or new( they are not real expensive)
and replace.
TaDa
have fun.
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
