Old 11-18-2010, 01:38 PM   #16 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by rbrowning View Post
I wonder what caused the hump in the curve for the Corolla? Aero? Surely it would have been in top gear before 60.
Originally Posted by EdKiefer View Post
you think its in high gear at such low speeds or is it somehow getting better mpg not in high gear .
I'm not surprised by it (only slightly so by the speed where it happens).
I have a hard time getting decent FE @ 90kph/56mph in 5th (top) gear, and it's the same with anything below 60kph/37mph in 4th.
The (smallish) engine revs low at these speed/gear combinations, barely 1600rpm.
I suspect it simply doesn't have the power to cope with the high loading.
A little bit faster, and it goes straight into its FE sweet spot around 100-105kph/62-65mph
Coming out of a deceleration phase and ending up in these situations, mpg will be OK. But any incline, or any attempt to accelerate will instantly result in a massive drop in mpg.
I've recently started to go back to 4th rather than stay in 5th, to come out of a tunnel on my commute and it seems mpg on the climb is better (or not as bad) in 4th.
I think I'm going to go ahead with an ECU remapping that gives more power and torque at lower revs.
I could use the odd extra 50 Nm around 1400-1600 rpm to bring the rpm down by 200-300 rpm - and drive in a higher gear.
As it is, the car needs a fair bit of throttle to get going smoothly.
HP and torque diagram of the Rica E-power remapping :
