Thanks peter,
I can't help you with that trike, I don't believe I've seen that one. Sounds
interesting though.
As far as bent building progress...
I just bought some brake cables and a new tube for the front wheel. i also found my old chain breaker tool so i can start putting a long chain together this weekend. Looks like I need to start fabricating the seat. Seems I can't do too much more without a seating position. The brake cables need a finished handlebar assembly and the handlebars need a seat to select the proper lengths. I'm thinking about mounting the shifters to the top tube in front of the seat somewhere instead of on the handlebars. That will keep the cable mess to a minimum.
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
