Thread: New CRX Owner!
Old 11-24-2010, 10:07 AM   #35 (permalink)
barchetta
1990 CRX HF unmolested
Originally Posted by kllymichele View Post
Could you please share the error? We cant help you if you couldn't provide on which part is the error! cause everyhing goes well with me!
If you read my post again you should see the error.. let me try again.. always make sure you can loosen the fill point first.. if you drain the fluid and you cant fill the transmission what are you going to do? This may not be a common problem on this transmission but its just common practice for any MT.
