You are referring to galvanic corrosion, which is not a huge problem between aluminium and steel. And in any way, the aluminium will be the metal corroding faster, not the steel, as it's the least noble of the two.
You should always apply/reapply a good protective layer over metals anyway to prevent corrosion from happenning.
