Old 12-13-2010, 03:22 PM   #40 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Originally Posted by slogfilet View Post
I'm wondering if another experiment might be needed...
To redo this experiment would require several nights with consistent outdoor temperature:
Day 1: run heater for 15 minutes, crank engine to mix coolant, check temp.
Day 2: run heater for 30 minutes, crank engine to mix coolant, check temp.
Day 3: run heater for 45 minutes, crank engine to mix coolant, check temp.
Day X: run heater for 15*X minutes, minutes, crank engine to mix coolant, check temp.
That's a good idea! I've been making a mental note of outdoor temperature, heating time and coolant temperature, but my mental notepad got a memory overflow error (I've got the old model with only a few bytes of memory). I should make a habit of writing it all down in my trip log.
Originally Posted by ConnClark View Post
My car came with a 400 Watt true block heater from the factory. The elements are right in the block underneath the head. I find that just 15 minutes of use makes all the difference in the world as far as getting the thing started. I get no white smoke from incomplete diesel combustion and the starter spins the crank much faster.
Looks like you've got a big ol' AC powered glow plug. :jealous:
Piwoslaw's Peugeot 307sw modding thread
