Old 04-22-2008, 09:00 AM   #25 (permalink)
PaleMelanesian
PaleMelanesian's Avatar
PaleCivic - '96 Civic DX Sedan
90 day: 74.33 mpg (US)
When you do a fillup, you can adjust the gallons. It'll apply that % adjustment to the fuel flow numbers from then on. You can change it on the fly within the first gallon of the new tank, too.
When I fill up, I record actual gallons and Scangauge gallons, calculated back to remove the offset. In my case it's +8% gas = -8% mpg. I have a running average for the difference, and use that as my default.
Also, the Speed adjustment also affects miles, so you can lock that in to whatever you want.
- - - - -Best 11-mile commute: 105 mpg
- - - - -Best tank: 88.5 mpg / 1133 miles
