Old 04-22-2008, 07:03 PM   #27 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Originally Posted by dremd View Post
My Scangauge is never accurate, always reads to much fuel flow on higher flow rates and to low of flow rates at lower flow rates. Basically the Curve is off. Likley a Diesel Only issue . . .
I assume you've selected Diesel as the fuel in one of the sub-menus. IIRC, there's Diesel-1 and Diesel-2 -- have you tried both? If so, is there better accuracy with 1 over the other?
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
