Old 12-22-2010, 09:39 PM   #5 (permalink)
jamesqf
Originally Posted by order99 View Post
I hope to have one of the simple DIY Solar Air heaters done in a few weeks-my version will use Soda cans...
Have you figured out how to get the tops and bottoms off the cans? I've tried hole drills & cutters, but the sides of the cans are so weak that the drill just grabs and twists them out of shape - if it doesn't send the can flying.
With the bubble wrap, I've made wooden frames that just slide into the window openings. A bit of foam around the outside edges makes a tight seal.
