Old 04-23-2008, 05:30 AM   #16 (permalink)
Chris D.
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
I heated up the plastic a little more since the adhesive was holding it in place..
turns out heat plus adhesive wasnt too good of a call LOL
came apart a little bit..
so I just filled it in with this other stuff I bought called Professional Welder..
The Loctite stuff was sweet to work with before I went at it with a heat gun..
I simply used the wire wheel deal on a dremel and the adhesive wears away before the plastic..
So I'll just use this Professional Welder stuff to "grout" it flush and just grind it down and a few payers of primer and It'll be good to go, I still have to add the other pod on the upper side..
The Profess Welder stuff takes 24 hours to setup, so I have some pressure on it..
If I had it my way, I would have bought lots of that Loctite and made quick work of it..
this too is stuff I've never used.. hit or miss, no biggie.. gadda experiment
with new materials all the time or ya never find the bigger or better..
