Originally Posted by SVOboy
Sounds ambitious, I'm definitely looking forward to watching your progress,
Hopefully the numbers are realistic.. The 96lbs of rotational mass should be about the same as removing 288lbs of static weight(1:3) though ive heard as much as (1:8 which would be 768lbs) and as low as (1:2 which would be 192lbs).. est 3% improvement in mpg from tires and rims, less rolling resistance, plus a lower center of gravity, less frontal drag, less tire exposed to airflow, plus less drag underneath with some aero mods, and a spoiler for that 10 degree goal from cab to end of bed will hopefully equal a 7mpg mix gain..
