Old 04-23-2008, 07:50 PM   #15 (permalink)
aerohead
T-100 airdam
Great looking! And I'm pleased that high-tech caveman tools are enjoying wider appeal than just North Texas.I can't tell how low that puppy hangs.The big-boys say,don't let it extend below the elevation of say the bottom of the rear axle,or drag will go back up,due to increased frontal area.Also,if the angle from the bottom gap at the front wheels to the bottom of the airdam is less than 15-degrees or so,you run the risk of clobbering that beautiful handywork on the nearest driveway ramp.Really clean fabrication,hope you get a little payback at the pump.
