Old 04-24-2008, 08:41 PM   #57 (permalink)
jpgmtech
duramax - '05 Silverado LT
Originally Posted by Chris D. View Post
but the engines an overkill for how much of it you'd
actually be using if you were aiming for fuel mileage..
If you could adapt an MDS setup to it, Game on!
I never understood how the MDS system could work without damagine
or causing excessive wear to the block pistons that arent being fuel'd..
The cylinder deactivation works great! I have it in my Grand Prix GXP. The only problem is that it's performance tuned, meaning it doesn't run in 4cyl mode very much at all... A little ECM tuning will help, still working on that one.
This feature comes from the factory on quite a number of GM V8's right now, just not in the corvette. The nice part about the 5.3 in a newer vette is that it would bolt right in with no adaptation other than ECM programming.
