Old 04-25-2008, 12:38 AM   #45 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Infrared experiment, trying to detect when fluid is in a tube.
Picked up some electronic bits on the way home:
Thought I would see how the clear tube behaved in the infrared spectrum:
the LED by itself:
the LED through the empty tube:
the LED through the tube with water in it:
Am I imagining things or is it much brighter with the liquid in the tube? That is not what I expected.
P.S. Here is the intended display device
Edit: Apparently water vapor is a good IR blocker, which explains the results. Will need to retest with gasoline.
