Old 04-25-2008, 08:22 PM   #2 (permalink)
LostCause
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Those are what I've been calling side skirts. I've written elsewhere on the site about their potential benefits (as I see them). Don't mean to be lazy by quoting myself, but why repeat?
This explanation wouldn't really apply to those skirts as they aren't extensive enough, nor is its underside built up to maximize their benefits.
From the thread "Win $100"
Frank Lee - "If there's a completely smooth belly pan, what good are side skirts? And vice-versa."
There are three primary reasons I can think of: yaw angle, spillover (for lack of a better term), and downforce. When I have more time, I'll describe each in more detail and with greater accuracy.
Yaw angle refers to the apparent air velocity direction under the vehicle. I need to refresh on the exact mechanism, but essentially high pressure air at the front underside of the vehicle tries to escape out the sides rather than flowing continuously back. This air travels obliquely to the direction of vehicle travel (which entails a energy loss in itself) and in doing so hits the wheels. While the front wheels show the greatest effect, the rear wheels are also affected. The wheels, which visually appear to have a small aerodynamic cross section, are much more dirty due to this oblique airflow. Skirts physically block off this phenomenon by removing the "easier" route for air to follow. Skirts allow the air direction to stay closer to the direction of vehicle motion.
Spillover is very similar to yaw angle, but it just describes the mixing of two regions of different pressure. Like the tips of wings, where high pressure air tries to rise up to the lower pressure upper surface, differences in pressure between the bottom of the vehicle and sides cause the direction of airflow to be altered. The more you change the air surrounding an aerodynamic body, the more drag you create.
Lastly, as Lotus had done with their open wheel race cars, side skirts allow the creation of a venturi under the vehicle. While the venturi would create downforce to counteract the lift generated on vehicles, I am not 100% sure whether this counteraction would decrease cL. Lift, as measured by the lift coefficient, brings rise to induced drag. As unintuitive as it might seem, cars generate lift like airplane wings and create the same type of vortexes. I suppose at the very least it would allow corners to be taken at higher speeds, lowering the use of brakes...
- LostCause
