I'm off to pick u part to get a FI resistor and its connector. Mine measures 2 ohms, but I want to make an adapter cable to bring the kill switch and both sides of the resistor into the cab. That way you aren't bypassing a fuse, cutting into wires or any of that. If a setup doesn't work, unplug the adapter and you are back to stock. Stock is important for California smog tests.
