Old 01-28-2011, 07:05 PM   #30 (permalink)
botsapper
PSmodder lurker
Thanks Euromodder,
Recommended aero templates and fastback angles will come out from many people...
Magical numbers of 10-12 degrees.
Here are just visual concepts. (quick tire change time is valid, could use quick release 1/4 turn camlocks or just delete)
Conceptually, there are rear vertical fences that holds the new lexan rear window/fastback at the best low drag angle. Ideally a true tapered boattail is the best but this might be the easiest to fabricate & even easier to test & adjust the back angles. You could also adjust trim edges depending on your track venue.
Other aero masters could chime in...
Name:	aero neon1.jpg
ID:	7735   Click image for larger version
Name:	aero neon2.jpg
The Following User Says Thank You to botsapper For This Useful Post:
Mira (05-01-2013)
