Old 04-27-2008, 09:05 PM   #174 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Originally Posted by mimsmetro View Post
what are your front tire dimensions?
All four tires are 175 80 R 13's
Yeah, that's a bit perplexing.
Were there any other changes? Had you somehow adjusted your driving style thinking alternator-off was compensating?
You need a MPGuino! (Did I miss the latest chapter in the SuperMID build? What happened there?)
No driving style changes that I noticed on that tank. Four tanks ago I had a similar freak 49mpg fill too...
I have been noticing that my fills are about 1 gallon less than they used to be a few months ago, but the needle is always in the same place (on empty) when I fill up.
Dunno if that has anything to do with it.
I have noticed that I've made some major driving improvements since going "beltless"
I'm coasting a lot more, trying to minimize the use of the starter and the time spent with the engine on, thus "hyperwatting" my limited battery power.
The next tank should be interesting.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
