Old 04-28-2008, 01:52 PM   #17 (permalink)
Duffman
I also agree with the suggestion that a .525 overdrive gear might be to deep. I would run the engine at the target RPM in the current OD gear and see how it responds at that RPM and find a small slope to approximate the increased aero drag from the higher speed you will see at that RPM with the deeper OD gear.
