Old 02-28-2011, 02:50 PM   #30 (permalink)
jedi_sol
jedi_sol's Avatar
2013 STi *SOLD* - '13 Subaru Impreza WRX STi
Subaru
Sports Cars
Team Turbocharged!
90 day: 26.59 mpg (US)
1996 Geo Metro *RETIRED from Ecomodding* - '96 Geo Metro Base
90 day: 58.68 mpg (US)
Originally Posted by Punchanello View Post
I know this is kinda off topic but your grill block was done out of Coroplast as well right? How did you attach it?
Version 1.0 was attached using clear packing tape.
Version 2.0 was attached using L-brackets from home depot and some bolts and nuts.
Version 3.0 (current), is a made out of of coroplast/fiberglass and shaped to fit the grille opening a lot better. Then used bondo to fill up the gaps and clean up the edges. It's still attached using L-Brackets/bolts/nuts.
I didn't put enough layers of fiberglass so it is warping on its own, but its been too cold this winter to continue working on it. Hopefully i'll get around to fixing it in the spring time.
As far as mounting points for the L-Brackets, i screwed them into that horizontal bar that runs along the middle of the grille opening.
See the rest of the Sti project log:
http://ecomodder.com/forum/showthrea...log-26612.html
