Old 03-04-2011, 06:23 PM   #19 (permalink)
dremd
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Originally Posted by johnlvs2run View Post
What is the difference between a cheapy one and one that's expensive?
There are some 300 psi 12v compressors on Ebay for less than $20.
the cheap ones run for about 10 mins before over heating. Sometimes they recover, sometimes they do not.
I highly recommend the Yellow one at Pepboys. Often times on sale for $25 Sometimes on sale for $20 You can always return to pepboys as well. It will run continuously for 6 truck tires (Load range E 245 75 R16 i think) from 30 psi to 90 psi without missing a beat. However, make sure that you outlet is up to snuff, these pumps draw a SOILD 15 amps at 12 volts.
6 speed ALH TDI
The Following User Says Thank You to dremd For This Useful Post:
johnlvs2run (03-09-2011)
