If you want to only use one switch and keep everything working find what voltage it has running through it and if it is normally open or closed. Once you do that find a suitable low power relay or two and use that to show that the clutch is pressed. If both switches operate the same way you might just be able to build a Y connector and run it to both locations.
 I move at the speed of awesome.
