Cfd & weight: 2 dr vs. 4 dr Metro?
Hello all,
First post here! Does anyone know the difference in CFd and weight between the 2 dr hatchback metro and the 4 door? I'm referring to the late 90s/early 2000s body if that helps, but if you have info on the earlier body that would help too. I know the 4 doors came with the 1.3 four cyl. but depending on the numbers I might be inclined to swap the 1.0/5 spd into the 4 door.. so it becomes a question of which is smoother and how much more does the 4 door weigh. Trying to decide which to go with.
Thanks! - JJW
