Old 04-30-2008, 04:23 PM   #24 (permalink)
IWillTry
Will you?
Just wanted to point out that air density was included in the original spreadsheet as a constant that the user could change. Fabrio's modified sheet simply adds a calculation of the air density based on more measurable quantities (temp, pressure, humidity, etc). Your best bet is probably to measure these directly at the test site using a mini weather station rather than rely on information for your larger region.
www.IWillTry.org - Will you?
