Old 05-01-2008, 10:50 AM   #12 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by tjts1 View Post
Because of this input to the ECU, any efficiency gained from the low density hot air going into the engine will be lost because of retarded spark timing.
That is assuming a lot. Do you have anything to back this up? AFAIK IAT is not a primary determinant of timing.
The work around this problem would be to manually control the input form the AIT sensor in order to trick the ECU to advance timing. This seems extremely dangerous to me.
That is hardly dangerous unless you floor it, and is a non issue with knock sensor equipped cars.
www.HyperKilometreur.com - Quand chaque goutte compte...
