Old 12-14-2007, 10:17 PM   #4 (permalink)
AndrewJ
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
So I got the rear fairings finished up and installed. They need a little bit more coaxing with the heat gun in places. That and the heads of the bolts and the washers need a good coat of white paint.
For all those interested in using ABS in the future please note that it will discolor if you heat it up too much with the heat gun, so heat up the back side of the piece so you wont see the discoloration when it is installed.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
