Originally Posted by vtec-e
Mind you, you could always do some internal mods like hotter thermostats, block heaters, lighter oils etc. Some underside mods like belly pans could be done while retaining a standard look. Have you started a fuel log here? Make sure you do it!
Hotter termostats - VW did it
Block heaters - VW did it
Lighter oils - VW did it
belly pans- VW did it
If you have the time take a look at this article abaut the lupo.
http://www.volkspage.net/technik/ssp/ssp/SSP_218.pdf
