Old 05-02-2008, 09:59 AM   #14 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
For the temperature you are talking about using 90% rubbing alcohol as the working fluid should work pretty well, for colder temperatures you can use things like propane, freon, butane, if you get really hot then you start to use things like water, like the evacuated tube solar hot water heat pipe collectors do, and with them it's an ounce or less of water, not much at all.
