Old 05-03-2008, 01:43 AM   #1 (permalink)
Nerys
Grrr :-)
Nerys's Avatar
Cherokee - '88 Cherokee
90 day: 19.44 mpg (US)
Ryo-Ohki - '94 Metro Xfi
90 day: 50.15 mpg (US)
Vger 2 - '00 Grand Voyager SE
Commute Route - Suggestions
I found the most efficient route to work. its a long nearly 54mile commute.
http://tinyurl.com/5qz2gd
Thats the point to point route I take. The other route I used to use is
http://tinyurl.com/3w8g4h
While the second uses more major roads it has MANY more lights and more stops and turns. My new route is just a single left turn after getting across the bridge. The new route dropped my fuel usage by nearly 8% and is actually faster (fewer lights and the few I DO see I can usually get through without stopping)
I also have this route available to me as an option
http://tinyurl.com/4s9qnm
But it has some problems. its 18 miles longer for starters BUT it would eliminate MANY stops. I could cruise at 60mph for almost the entire trip. While higher speed means more fuel less stops would compensate somewhat. BUT this route has a problem. While there is no tolls going out I would be going out at 4pm meaning I would be screwed on I-95 (rush hour) even if the traffic is relatively light its gonna eat the fuel.
Now on the way home it would be ZERO traffic but now I would have $5 in tolls ($2 to get on the Expressway and $3 to go across the bridge) that would destroy any fuel savings and then some :-( so I think I am better off with the route I have now.
Suggestions?
