Old 04-15-2011, 02:33 PM   #19 (permalink)
dennyt
in tents
dennyt's Avatar
The Adventure Wagon - '94 Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '011 Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
CarloSW2, that is correct. The IAC has a 1/2" inlet hose, which is very easy to access. So, I drilled out a dime and stuffed it in the hose, right on top of the valve.
PLTW - I agree that a block heater is the better way, I have plans to install one. But until that happens, I'm reducing my warm-up idle speed (with this mod), and I've already put a resistor in parallel with the CTS to reduce cold-start enrichment. I have a knob on the dash, I can lean it out as much as I like when it's in open-loop.
Cheers,
-Denny
The Following User Says Thank You to dennyt For This Useful Post:
cfg83 (04-15-2011)
