Old 05-04-2008, 11:03 AM   #7 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
When you get right down to it, a custom conversion is just that custom. Unless there is a related engine or body that uses the same engine, forget about it, and just choose the engine and tranny set up you want for the vehicle. In order of difficulty;
-Fabricating solid engine mounts
-Making room in the transmission tunnel/ Fire wall, if need be
-Fabricating new tranmission mounts
-Having a custom drive shaft made to accept the tranny of one car and the rear end of another.
Hopefully you'll choose an engine with minimal electronics to make that part easy. So find yourself a good welder and a junk yard with lots of engines and happy hacking.
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
