Old 05-04-2008, 10:49 PM   #17 (permalink)
guitarterry
stinky - '97 metro lsi
90 day: 44.71 mpg (US)
To answer your question metrompg. Just 2 things. 1. Mpg cruize control. it would need adjustable minumum and maximum speeds for going up and down hills. Also it would need adjustable gain so that again as you are going up and down hills it would be able to adjust how much you slow up and speed up. 2. would be downloadable stats with the ablity to add gauges. example would be if you wanted to monitor the oil in the rear end (differential) you could add that function. With this system any car could use it cause its expandable. kind of like plug and play on the computer.
