I am overall pretty happy with the weight so far. If I can save a little here or there with parts I already have on hand that's great. The rear wheel swap will only save me 1/2 lb but the tire, freewheel, and bearings are 99% better than the old wheel.
The seat cover is slow going. I started pinning it in place but my 2yr old daughter wanted to "help"
so I didn't get very far.
The important thing with weight is.... Don't try to save a few ounces on components if the bare frame is the bulk of the weight. as long as you're focused on a)easiest/cheapest to lighten and b)what's heaviest to begin with - you're doing well "b" typically is the engine
That's a very good point. My engine will probably drop a few pounds trying to get efficient at riding again
