Hahah, no. I'm not sure how I'm being so incomprehensible. Let me try once more. I've tried two entirely separate ways of clutch starting.
1. Normal way. EOC, then key on, then let the clutch out. This is the method where letting it out a little and then putting the clutch back in doesn't seem to start the engine.
2. Other way. EOC, the slowly let out the clutch, after engine is already spinning THEN key on.
