Old 05-05-2008, 11:29 PM   #5 (permalink)
corvette2000
IHATEGAS
corvette2000's Avatar
I found this piece of info on a web site about using the ac or rolling down the windows in a car here what it said.............................................. .........................
The A/C compressor pulls power from the engine wasting some gas, the effect appears to be minimal in modern cars. The A/C can lower the fuel efficiency from 10 to 20 percent depending on the type (and age) of your vehicle. Using the air conditioning does require your vehicle to burn more fuel, but it is more efficient than driving with the windows down. Putting the windows down is not a good idea. Putting the windows down tends to increase drag on most cars, canceling out any measurable gain from turning the A/C off. The increased drag of the car means your vehicle will have to work harder, because of the change in the aerodynamics. Therefore, open windows cause your car to burn more fuel.
