Old 05-06-2008, 08:03 PM   #5 (permalink)
Wayneburg
Originally Posted by dremd View Post
If you do bed liner DEFIANTLY USE A GOOD RESPIRATOR the stuff is POTENT.
I've used it on several interiors before, use a respirator, only spray for 3~5 mins, open doors, use a fan and you are ok. <- Not Official OSHA Advice
Good advice that I definitely plan to follow. But, I'm also concerned with this stuff continuing to offgas long after it has dried. If it contains VOC's I want to make sure it's at least at a low level. 150 gm/l or lower.
