I found a filter, and it is tapped for a nozzle. The filter will go behind the grill with a shield. it will mount to the turbo, and the nozzle will pretty much aim at the turbo. it's set to start at 7 psi. The only thing I don't know what to do with is the IAT sensor. it is mounted in the airbox, alot of good for a turbo car, but that is where it is. Do you think I should move it closer to the filter?
