Old 05-12-2011, 09:45 AM   #12 (permalink)
mora
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Simply type save and hit enter to save settings.
I have an issue with rtd period parameter not saving the value. It stays for a session but doesn't want to stay in memory even if I save settings.
I calibrated my throttle by setting maximum allowable amps to 10 and checking that potentiometer was at resting position. Noted value from RTD explorer. Then I floored the pedal and noted value for throttle max counts.
Note the correct parameter for setting throttle raw counts (an example below):
t-max-rc 500
t-min-rc 800
The Following User Says Thank You to mora For This Useful Post:
mrbigh (05-12-2011)
