Originally Posted by Dust
I found a filter, and it is tapped for a nozzle. The filter will go behind the grill with a shield. it will mount to the turbo, and the nozzle will pretty much aim at the turbo. it's set to start at 7 psi. The only thing I don't know what to do with is the IAT sensor. it is mounted in the airbox, alot of good for a turbo car, but that is where it is. Do you think I should move it closer to the filter?
water injection before the turbo will cause erosion of the impeller. Think about the bits of metal will do to your engine. I'd also suggest you read this before considering a warm air intake on a turbo'd vehicle
Compressor Efficiency and More
