Old 05-06-2008, 11:27 PM   #10 (permalink)
capn
Goal: Save the world
capn's Avatar
Caddy - '94 Eldorado ETC
90 day: 20 mpg (US)
I don't think you'll find any gain with a restrictor plate. Your butterfly valve is your restrictor plate. If you put something else upstream/downstream from there that forces you to open the throttle to compensate, you're not actually reducing pumping losses (if that's your goal). If your goal is to simply restrain how much power you use, you can do that with your brain & right foot .
You're heading in the right direction, looking @ your fuel log.
my goal with a restrictor plate is not to limit my power use, rather the engines output and consumption.
I am also not trying to reduce pumping losses, this is just adding more restrictions in hopes it might trick the MAF that the engine needs less fuel. Although testing is required.
"what gets us into trouble is not what we don't know. Its what we know for sure that just ain't so." ~Mark Twain
