Old 12-16-2007, 01:47 PM   #5 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
thealterecho quote
thealterecho said:
Originally Posted by thealterecho
Think about this. The stock filter creates a resistance when the engine is sucking in air,some vehicles more then others.Think about when you put 2 cups together that are nearly the same size. When you go to pull them apart it is almost inpossible at times because there is a resistance. This is example is to give you a good idea although it is not exactly the same because one side of the filter is not completely blocked off to air as the cup. But if you poked a small hole in the back of the cup then the cup that was slid in would come out easier. If you make a big hole on back of the cup it will come right out. Because the air did not resist. It flowed straight thrue the cup that had a cup in it. Same concept. Resistance abosrbs energy.
Not only does it create less resistance but it makes for a more combustible enviroment enabling the engine to compact more air into the cylinder at any given time.
It is only logical that a better flowing filter make better MPG.But that does not mean it flows signifigantly better on every vehicle it is apllied to so I am not saying all vehicles will see an increase but I have never had a vehicle not increase in MPG or power with a K&n filter. I cant speak for anyone else.
