Old 05-17-2011, 01:07 PM   #50 (permalink)
gone-ot
...beats walking...
Originally Posted by TheEnemy View Post
Thats MACH index as in speed of sound?
...yep.
...quoting from page 245 of Taylor & Taylor (Compressible Flow Through a Fixed Passage, in Chapter 10):
"Inlet-Valve Mach Index. Some years ago (10.41) experiments were made under the author's direction to determine if some easily evaluated velocity could be used for µ in Eq. 10-17. The velocity finally chosen was the following:
µ = (Ap·s)/(Ci·Ai)
where Ap is piston area, Ai is nominal inlet-valve opening area, and Ci is the inlet-valve flow coefficient based on the nominal area Ai. It will be noted that the resultant value of µ is the velocity of an incompressible fluid through an opening of area Ci·Ai into a cylinder of piston area Ap with piston velocity s. Using this nominal velocity, the ratio µ/a in Eq. 10-17 can be written:
µ/a = (b/Di)^2 × [s/(a·Ci)] = Z
...where:
b = cylinder bore;
Di = inlet-valve diameter, the nominal inlet-valve area being taken as (PI·Di^2)/4;
s =mean piston speed;
a = inlet sonic velocity;
Ci = inlet-valve average flow coefficient."
"...the variable, µ/a, refers to the Mach index [Z] through the controlling flow section, which is usually the inlet-valve opening."
"...Mach index (Z): Z = (b/Di)^2 × [s/(a·Ci)]"
...and, lastly, from pages 248 and 249:
Page 248: "Effect of Piston Speed. Where piston speed is the only variable, the effect on volumetric efficiency is through Z, which is directly proportional to piston speed."
Page 249: "One important relation is observable...namely, that volumetric efficiency starts to fall off rapidly as Z exceeds 0.5 to 0.6."
"...from the aforementioned considerations...the inlet-valve size and design should always be such that Z will not exceed 0.6 within the operating regime of any engine."
...and, similar, but higher order limitations (due to higher pressure and gas temperature) occur getting exhaust gas through/past the exhaust valve.
addendum: see posting #53 below
The Following 3 Users Say Thank You to gone-ot For This Useful Post:
aerohead (02-22-2016), Christ (05-17-2011), TheEnemy (05-17-2011)
