Thread: Aeromods V1.0
Old 05-07-2008, 11:46 AM   #1 (permalink)
trikkonceptz
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '010 Insight EX
90 day: 51.5 mpg (US)
Vibe Aeromods V1.0 - infinity
Ok so I have started the aeromods on the Vibe, stage 1 is simple, seal off unecessary holes and see what happens.
Well as you can see by the pics, I sealed off the grille and the fogs, also removed the roof rack, which uncovered an unpleasant issue.
Looks like the Vibe, unlike the matrix was not intended to be without a rack. What impact do you think this will have on the grand scheme? Should I put the cross bars back on? I'm sealing open holes otherwise and any water falling through the hole simply drains through the hatch, so those are not my concerns, the aero impact is ... your thoughts ??
Next week if this works the holes will be covered with proper blocks likely made from abs plastic ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
