I'm not running a scanguage, but there was no movement in the temp needle at all. Yesterday is was over 90degrees here and I therefore did some intentional city driving to see if the car would overheat, but no ...
I did discover that my thermostat for the dash readout has to be somewhere behind that grille though, because all day long it read in the high 90's instead of actual accurate temps ....
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
