Old 05-07-2008, 07:21 PM   #1 (permalink)
Dan.
MPG Centurion
LinuxPC + FreeDiags + Freefall OBDII<->RS232
I know it won't do CAN, but this is what I was trying to do way back when
http://www.cleanmpg.com/forums/showthread.php?p=92392
I've seen a lot of posts complaining that the SGII is too expensive. In answer to that I've dug through my bookmarks. There was a time in my life where cheap was better than easy. Now I'm not so picky.
So what you need:
  1. A i386 laptop or better with serial and LPT port (0 - $10) - Should take 8 - 40 hours depending on your ebay skills. If someone charges you more than $10 for a 12 year old laptop... punch them in the nose.
  2. A Linux kernel capable of running on #1 ($0.00) - This will take between 4 - 4000 hours depending on how good you are at assembling Linux Kernels.
  3. http://www.planetfall.com/~jeff/obdii/ ($5 - $10) - Should take 16 - 200 hours depending on your digital logic skills. You'll need the proper project boards a hot iron, a laser printer (library) and a good amount of etching acid. Add the proper parts and a soldering iron and you have a (car) OBDII - RS232 (serial) adapter. Make sure not to melt any skin in the process . You don't have to use these plans, just one of the ones supported in the the software in #4
  4. http://freediag.sourceforge.net/index.html ($0.00) - Should take 8 - 400 hours depending on if bugs arise. Checkout the source and compile it targeting #2. This is the software that will talk to your car using #1 through the adapter you made in #3. Please take care to do step #3 properly so as not to fry out your serial port or your cars OBDII port.
So between $5 - $20 cash and between 36 - 4640 hours (0.9 - 116 work weeks) of time.
I made it through step #2 two years ago before giving up and buying the ScanGauge. Cost me $0.00 and about 200 hours of effort.
Don't think this stuff works on CAN cars but feel free to update the freediag software or Jeffs OBDII schematic.
11011011
Houston Hybrid and Hypermilers Club <106mpg.com>
Best commute = 14.3mi @ 114 MPG (sg2)
Best (non-trivial) tank = 759mi @ 80.7 MPG (fcd)
MPG Centurion-Hybridfest 2007-Prius II-26mi @ 106 MPG (sg2)
Dan <11011011>
