I don't think so either. Its work to get a diesel to 25mpg. Maybe if you did ton s of aeromodding, tall tires, 2.73 gears, etc and spent the whole tank at 40 mph. You might get close. Gas trucks do not tolerate lean mixtures, you'll cook a valve, toast a rod bearing, blow head gasket, etc.
