Old 06-06-2011, 08:55 PM   #10 (permalink)
IamIan
IamIan's Avatar
Originally Posted by bwilson4web View Post
Unfortunately, I can't use temperature change to quantify the stirring and friction losses because of MG1 and MG2.
Why not?
Say you're in EV-Mode.
You have
Power flow MG1
Power flow MG2
Trans-axle losses
Combined those are your heat sources to deviate from ambient.
The source of MG1+MG2 heat contribution is their power flow and their efficiency map... which as I recall that motor efficiency map has been done.
If you quantify the contribution from MG1 + MG2 what dT is left is from the trans-axle itself.
