Old 05-10-2008, 09:38 AM   #31 (permalink)
larrydag
FuelSipper
HondaHokie - '95 Accord DX 4 door
90 day: 26.91 mpg (US)
Originally Posted by dcb View Post
Ok, just a couple q's when you get to them and before I forget them.
You got the LCD from NCK, correct? I don't know if any others would be significantly different or not, and don't want to know just yet.
Yes, its the NCK LCD
Can you run it on just external power (i.e. a wall wart of 9-12 volts DC with a plug that fits and center pin positive, or that 9 volt battery trick)? Don't forget to move the jumper. Does it display correctly connected to just external power?
Yes I've tried powering it up with a plug in power supply. It did the exact same thing.
Have you triple checked the wiring against the diagram? I'm pretty sure the diagram is correct because I used it to swap in the serial board.
What if you disconnect pins 2,3,14,17,18,19? if disconnecting them all helps, is there a combination of pins or a single pin that the problem can be isolated to? Hit reset bewteen pin connection tests so the LCD will reinitialize.
I'll give that a try. I have been double checking the wiring but there is a lot of wires. I'll try to see if I can isolate it.
