Thread: Low cost BMS
Old 07-08-2011, 09:01 AM   #10 (permalink)
sawickm
ReVolt Enthusiast
Originally Posted by harlequin2 View Post
This uses a single board per cell, each board measures the cell voltage. The cell modules are done and I am working on the master with the intention of modifying the Cougar LCD unit to handle these functions. My first iteration is a stand alone micro/LCD though, with the merging with Freyguy's design a bit later.
What type of battery does your BMS work with Lion or SLA? Both would be nice, most DIY'ers can only afford SLAs. All of the BMSs on the market are only for Lions.
It would be nice if you could also interface your master controller to "Adam's" open source 6Kw charger http://ecomodder.com/forum/240533-post37.html.
It would be great to see a ReVolt open source Motor Controller, DC Charger, BMS, and LCD Display all connect to each other as a complete system !!!
-Mark
